Activity › Forums › Adobe After Effects › best way to output this comp
  • best way to output this comp
    Posted by Alistair Chisholm on November 18, 2005 at 10:44 am
    I have my main comp which is 4:30 mins long. The resolution is 1024×576. I am wanting to output this so it will run continously in a loop (using something like windows media player) on a Pc as part of a window display. I therefore need maximum resolution and quality, but also not a ridiculously large file that might make it stutter on the average Pc.
    Any advice?
    Cheers
    Alistair
    Michael Szalapski replied 20 years, 10 months ago 3 Members · 2 Replies
  • Steve Roberts
    November 18, 2005 at 2:19 pm
    The Windows Media Codec (WM9?) is surprisingly nice and playable, but if I recall, you can only render it from AE on Windows. Probably AE 6.5.
    And test it on the playback PC. Test early, test often.
    Steve
  • Michael Szalapski
    November 18, 2005 at 3:12 pm
    Halving the frame rate always helps too. 15 fps isn’t too bad on a computer. It kinda depends on the computer it will be playing on. For example, the computer I’m typing on right now would in no way handle full-screen full-frame video playback. The one just down the corridor, on the other hand, can deal with it just fine.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
