Activity › Forums › Apple Final Cut Pro Legacy › Best Way to Manually rebuild offline media
David Mosquera keith replied 17 years, 8 months ago 5 Members · 15 Replies
John Pale
January 16, 2009 at 10:16 pmAre you working with several long master clips or many smaller captures?
If you can determine the offset (not always easy), you can load the master clip into the Viewer and use the Modify/Timecode command to change the starting timecode by 10 frames (or whatever the offset is).
I have successfully done something similar to this replacing footage offlined with DVD footage (no timecode) and onlined with HDCAM.
Steven Gonzales
January 17, 2009 at 1:38 amDo you have an output of the cut from the timeline you are rebuilding? i
If you do, you could take that quicktime to a video track above the others, reduce it down to a small overlay, and match each clip cut by cut to that output by eye.
I’ve had to reconstruct project for folks that “captured now” without timecode, then had to recapture when their hard drive died.
This is why after capture, especially without timecode machine control, I make a backup of the files. Hard drives are in virtually unlimited supply, but my patience is a nonrenewable resource.
January 19, 2009 at 10:03 amHi Steven i actually wish i had an output of the timeline, as it was finished work…but the hard drive just died without giving any signs and i guess that ill learn from this one the hard way!
Thanks Dave Mosquera
January 19, 2009 at 10:39 amHi John this sounds good, the files are long ones.
Im trying this but i cant seem to find the modify/timecode is it in the main viewer or under the motion tab??
could you please point me out the steps in wich i should be doing this?should i first reconnect and then modify the timecode or the other way around?
I would apreciate if you could be more specific
Thanks David Mosquera
January 19, 2009 at 11:44 amUps! i realize you meant know, ive been trying this but havent got the result i hoped, when i go to modify then timecode i get a menu :
where it says Frame To Set: either Current or First (?) ( does this matter? )
then there is the option of Source or aux timecode to be modified ( wich one is it?)
oh and doing this ive actually broken a video file, it doesnt recognize it as a video file anymore…( so be carefull people doing this!)
Saludos Dave.
