Activity Forums Adobe After Effects best way to make hundreds of copies of a layer into a grid
  • best way to make hundreds of copies of a layer into a grid
    Posted by Grayson Sedory on April 23, 2010 at 12:56 am
    What would be the best way to take a layer made in photoshop and create a grid with it using hundreds of instances of that layer to form the grid? The idea is to be able to fly into different parts of the grid to illustrate different populations of people.
    Grayson Sedory replied 16 years, 4 months ago 2 Members · 2 Replies
  • Michael Szalapski
    April 23, 2010 at 3:17 am
    Here you go. Found it on here in Adobe’s improved AE help.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Grayson Sedory
    April 24, 2010 at 4:17 am
    Hey thanks for the advice, I tried using that Comp however, it ended up using way too many resources this way. I finally decided to use Stylize> Motion Tile and then duplicating the layer as neccessary and parenting the layers. I was able to create the exact look I need and would recommend this method if someone else has the same need.
