Activity Forums VEGAS Pro Best Way To Hook Up External Monitor
  • Best Way To Hook Up External Monitor
    Posted by Corey Whitley on October 16, 2008 at 2:43 pm
    I am using Sony Vegas 8 c and am trying to use an external monitor to preview video, but can’t figure out how to configure the decklink hd to the monitor. Any advice?
    Corey Whitley
    Corey Whitley replied 17 years, 11 months ago 3 Members · 6 Replies
  • Douglas Spotted eagle
    October 16, 2008 at 2:46 pm
    If your monitor doesn’t have an SDI card, you’ll need to use component out from the Decklink card to go component in. If you don’t have component in on your monitor, then you won’t be able to use Decklink (or any other SDI card).
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Enrique Orozco
    October 16, 2008 at 3:05 pm
    HDMI to monitor (with HDMI input) with proper drivers won´t be better ???
    regards
    October 16, 2008 at 3:12 pm
    the Intensity has HDMI, the Decklink does not.
    VASST
  • Enrique Orozco
    October 16, 2008 at 3:29 pm
    … I was thinking on the new one (Decklink HD extreme)…
    this is from their site:
    The new DeckLink HD Extreme is the most advanced capture card ever built. The new DeckLink HD Extreme includes all the powerful features of the previous model, but now adds HDMI capture and playback, plus new 3 Gb/s SDI support, and 3D lookup tables. Now you get all the power of film and high definition editing, at a standard definition price of only US$995!
    kind regards
    October 16, 2008 at 3:34 pm
    You’re right, I should ask if it’s a Decklink, or a Decklink Extreme. OP says “Decklink” so I made an assumption.
    Back to your original question…
    HDMI isn’t better than SDI, no. Depending on the monitor, it could even be inferior, albeit unlikely. HDMI is merely a “poor man’s SDI.”
    Since we’re talking about Vegas 6 in the OP, my assumption would be we’re talking about an SD card vs HD card.
    More info from the OP would help.
    VASST
  • Corey Whitley
    October 16, 2008 at 4:02 pm
    Thanks all. It turns out I just didn’t have my Decklink HD driver installed correctly for 64 bit. This has been a true trial and error.
    Thanks again.
    Corey Whitley
