Activity Forums VEGAS Pro Best way to handle mixed formats on timeline
  • Best way to handle mixed formats on timeline
    Posted by Rick Hughes on February 14, 2016 at 1:13 pm
    Usually all media comes from one camera so issue does not arise.
    However putting some compilation videos together … these have a mixed bag of media files.
    Typically 1920x1080p AVC/mp4 59.94fps AAC audio
    and 1280×720 AVC/mts 25fps Dolby AC3 audio
    I know I can mix these on the timeline, but a couple of what may be simple Q’s
    # Would I be better to convert prior to using on timeline to make videos same framesize, fps & same codec
    # If no need … then what should properties be set to … normally use match media settings – so which would I choose …. do I choose the one that matches the output ……. or if one doesn’t match, then set project settings to what I will be setting output as.
    In this case will be loading on line for streaming from Vimeo.
    I’ll use ‘Render As’ Sony AVC/MVC and I have 2 templates for Vimeo .. either
    1920x1080p 29.97fps bitrate 12,000,000 or
    1280x1080p 29.97fps bitrate 12,000,000 both using AAC audio
    John Rofrano replied 10 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    February 14, 2016 at 3:57 pm
    [Rick Hughes] “# Would I be better to convert prior to using on timeline to make videos same framesize, fps & same codec”
    That’s what any editor on a Mac would do… i.e., convert everything to ProRes 422 and edit happily without any problems. Unfortunately, the PC doesn’t have a common digital intermediary like ProRes so it’s not that simple. If your target is 29.97 fps you might want to render the 25 fps video to 29.97. Maybe use Sony MXF. This edits nicely in Vegas Pro and maintains good quality. Of course, Sony YUV was designed for this but the file sizes and huge.
    [Rick Hughes] “# If no need … then what should properties be set to … normally use match media settings – so which would I choose …. do I choose the one that matches the output ……. or if one doesn’t match, then set project settings to what I will be setting output as.”
    When using mixed media, you should set you project to match your delivery format. This way there are no surprises when you go to render. What you see in the preview is what you will see when rendered.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Rick Hughes
    February 14, 2016 at 6:27 pm
    What I may do is get all files to same format and save as Lagarith Lossless – huge files, but only used as intermediates.
  • John Rofrano
    February 15, 2016 at 4:48 pm
    Do a test to see how well Vegas Pro handles Lagarith on your computer first. You really only need to convert the files that don’t match the project properties.
    ~jr
