Activity Forums Apple Final Cut Pro Best way to go from FCPX to Protools
  • Best way to go from FCPX to Protools
    Posted by Edward Harby on March 2, 2014 at 12:29 am
    A lot of people have mentioned using Xto7 to create a xml from FCPX but where do I go from there? It looks like Protools doesn’t want an xml file. What’s the best solution with the least margin of error to get the XML into an OMF(or AAF) or anything that protools can read.
    I could open it up in FCP 7 and convert it to what it needs to be, but I still want to know what other people are doing with the xml file.
    Using FCPX on Maverick with Protools 11.
    Charlie Austin replied 12 years, 6 months ago 3 Members · 2 Replies
  • Patrice Freymond
    March 2, 2014 at 12:41 am
    X2Pro Audio Convert by MArquis Broadcast. We use it every day for a similar workflow, and it works.
    PF
  • Charlie Austin
    March 2, 2014 at 4:51 am
    [Edward Harby] “What’s the best solution with the least margin of error to get the XML into an OMF(or AAF) or anything that protools can read.”
    Yep, X2Pro, hands down. The LE version is cheaper, and is good if you’re in house as it doesn’t do handles and the files are enormous. The Pro version is the one to get. Not cheap, but works flawlessly, and if you’ve set Roles well it’ll split it all out really nicely for you.
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
