Activity › Forums › Apple Final Cut Pro Legacy › Best way to fix lines through video
  • Best way to fix lines through video
    Posted by Diego Garcia on November 20, 2008 at 10:45 pm
    Hello cow members,
    I am editing an interview on FCP6 (6.0.4 Academic)
    The problem is that I don’t know what format the video was shot in. Analyzing the footage in After Effects i got this: 720 x 480 (1.20) , Seperating lower – 23.976 fps 3:2 Removal – dv/dvcpro ntsc.
    So what I need to fix is the lines going though my subject when he moves around in the interview. Even the smallest movements cause the lines to occur. Here is a screenshot I uploaded.
    https://i36.tinypic.com/r1zous.png
    I have tried the de-interlace filter, which sorta helps but only to sacrifice the quality in other parts of the picture. Like jagged edges in his arm. ahh!
    ***I should add that my final output will be Web****
    Any help is much appreciated.
    Cheers,
    Diego
    Diego Garcia replied 17 years, 9 months ago 2 Members · 5 Replies
  • David Roth weiss
    November 20, 2008 at 11:02 pm
    You either captured the footage improperly or your settings on your timeline are wrong.
    As a test, open a new timeline, drop a clip from the browser onto the timeline, when the message comes up asking if you want FCP to match the timeline settings to the footage say yes. Then report back here and tell if the same issue stil exist.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Diego Garcia
    November 20, 2008 at 11:16 pm
    Thanks David,
    Ok I just did what you told me and I’m still getting those lines. I guess I captured the footage wrong? How do I properly capture?
    The way I originally did it was by going to the “Easy Setup” window and putting it in:
    Format: NTSC
    Rate: 23.98
    Use: DV-NTSC 24p (23.98)
  • David Roth weiss
    November 21, 2008 at 12:00 am
    Why don’t you try to capture a few seconds using the standard DV NTSC anamorphic capture settings, then check that out on a new timeline as I suggested before.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Diego Garcia
    December 10, 2008 at 12:41 am
    Hey David,
    Thanks again for your help. I’ve been gone but I am back and working on this interview again. So I recaptured using the standard DV NTSC anamorphic capture settings as you suggested but my footage is still getting lines through it during jerky movements by the subject.
    I would love to remedy this or at least try to make it look better.
    I have uploaded a sample on vimeo. https://vimeo.com/2477976 (should be able to view in a couple minutes.)
    Cheers,
    Diego
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Diego Garcia
    December 10, 2008 at 7:31 pm
    anyone? anyone? Or are these lines showing up because I’m watching it on my laptop’s screen? (mac book pro 17in)
    – D
