Activity Forums Compression Techniques Best way to export video to be played back on SD card.
  • Best way to export video to be played back on SD card.
    Posted by Shawn Romano on April 22, 2010 at 6:28 pm
    I am in need of some help. I’m editing some video footage that was recorded onto an SD card in 1080i, and would like to export and play it back on an SD card, via a BluRay player with an SD card slot. The player manufacturer (Panasonic) lists compatible SD card formats as AVCHD, MPEG2 and JPEG. Using Apple Compressor, I can output to MPEG2, but when I put the result on the card and pop it into the player, nothing is there? What am I missing? Ideally, I’d like to write back to the AVCHD format, but not sure if this is possible. Thanks!
    Daniel Low replied 16 years, 4 months ago 2 Members · 1 Reply
  • Daniel Low
    April 22, 2010 at 7:45 pm
    [Shawn Romano] “but when I put the result on the card and pop it into the player, nothing is there?”
    You normally have to create a directory structure, follow a naming convention or look for an option in the menus that show hidden file or shows ‘everything’
    Sent from my iPad Nano.
