Activity Forums Adobe After Effects Best way to export DV from After Effect to Premiere
  • Best way to export DV from After Effect to Premiere
    Posted by Alberto Bedin on September 14, 2010 at 2:45 pm
    I’m using both After Effect CS 5 and Premiere CS5.
    I have DV video 872×480 video sequences (they will become 16:9 720×480 PAR 1.21 video) and after working in AE I would like to move them in Premiere.
    What’s the best output format? I’ve seen that Premiere can open AE files but AE must be running and it’s also very very slow.
    I can export my video in MPEG 2 (final result will be a DVD), but Premiere will render them again, right? Is this a problem for the final video quality?
    Edit: I’ve just found this: https://help.adobe.com/en_US/AfterEffects/9.0/WS2EC46BBB-CD7B-45c3-A929-DE1F61EB7D10a.html
    Is this a good way?
    Michael Szalapski replied 16 years ago 2 Members · 3 Replies
  • Michael Szalapski
    September 14, 2010 at 8:58 pm
    I wouldn’t suggest that route in that webpage because that won’t work if you’re using effects that aren’t in Premiere. And I definitely wouldn’t do it as MPEG-2.
    Export a lossless file out of AE and work with that in Premiere. Quicktime with the PNG codec seems to give smaller file sizes while still being lossless compared to Quicktime with the Animation codec or a lossless AVI.
    This page gives some suggestions for working with AE and Premiere.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Alberto Bedin
    September 15, 2010 at 9:29 am
    Oh, really the export to Premiere function does not export all effects from AE to Premiere? I can’t believe!
    I tried your link but it doesn’t say anything about this.
    Please could you give me an example of no-exporting effect?
    So the best way is exporting in a lossless format? What about exporting as a tiff-sequence?
  • Michael Szalapski
    September 15, 2010 at 1:26 pm
    [Alberto Bedin] “the export to Premiere function does not export all effects from AE to Premiere? I can’t believe!”
    You don’t have to believe me, give it a try. Create a text layer and a solid in a new comp. Apply CC Particle World to the solid, then try that method of exporting your AE project as a Premiere project. Open it in Premiere. See what happens.
    TIFF sequences are good. Targa sequences are pretty good if you want transparency.
    – The Great Szalam
