Activity Forums VEGAS Pro Best way to convert this 3:2 to 16:9
  • Best way to convert this 3:2 to 16:9
    Posted by Griff Hamlin on September 4, 2013 at 8:26 pm
    I have some footage that is 3:2 (720×480 pixels square.)
    I would like to convert this to a 640×360 (16:9 square pixel)and/or NTSC Widescreen (also 16:9 but I don’t know if the pixels are square) by cropping the top and bottom and narrowing the remainder.
    I notice that when I use the crop/pan tool to do it, it seems like during times of motion that the footage becomes wavy. I used to think it was something with interlacing, but I believe it has more to do with the cropping/zooming based on some other research I’ve done.
    I saw something about using a mask, but I can’t figure out how that would work. Is there a better way to do this? Thanks.
    Here is the mediainfo from the source material:
    Format : Windows Media
    File size : 47.5 MiB
    Duration : 1mn 21s
    Overall bit rate mode : Constant
    Overall bit rate : 4 878 Kbps
    Maximum Overall bit rate : 6 294 Kbps
    Encoded date : UTC 2013-08-08 17:20:57.820
    Video
    Format : WMV2
    Codec ID : WMV2
    Codec ID/Info : Windows Media Video 8
    Description of the codec : Windows Media Video V8
    Duration : 1mn 21s
    Bit rate mode : Constant
    Bit rate : 6 000 Kbps
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Frame rate : 29.970 fps
    Standard : NTSC
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.579
    Stream size : 58.4 MiB
    Language : English (US)
    NumberOfFrames : 2431
    Griff Hamlin replied 13 years ago 1 Member · 0 Replies
  • 0 Replies
