Activity Forums AJA Video Systems Best Way to Convert Many PAL VHS to MPEG-1
  • Best Way to Convert Many PAL VHS to MPEG-1
    Posted by John Fishback on January 3, 2006 at 1:22 pm
    My objective is to develop the best workflow to convert lots of PAL VHS tapes to MPEG-1 using FCP and IO.
    I can think of two approaches.
    1) Buy a multi-system VCR with standards converter and input NTSC to FCP, trim digitized tapes, export refs and use Compressor to make MPEGs. Disadvantage is probably the quality of the standards converter. I don’t want to spend a fortune on this as it’s VHS and a one-time job.
    2) Buy only VCR that plays PAL. Install AJA’s IoAnalogPAL.mkpg and capture the PAL VCRs output as PAL. Trim digitized tapes, export refs and use Compressor to make MPEGs. Disadvantage is I can’t view input or digitized clips on my broadcast (NTSC-only) monitor.
    I am open to suggestions as to the benefits/drawbacks of either approach and for better ways of doing this. Also, if anyone has suggestions as to VCRs/standards converters I’d appreciate that, too.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
    John Fishback replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
