Activity Forums Adobe Premiere Pro Best way to convert 25fps to 50fps
  • Best way to convert 25fps to 50fps
    Posted by John Mark on September 27, 2013 at 7:42 am
    I am wanting to convert 25fps (progressive) to 50fps. Is there a good way of doing this in APP?
    -Thank you in advanced
    A News Graphic Lover
    Ivan Myles replied 12 years, 11 months ago 2 Members · 5 Replies
  • Ivan Myles
    September 27, 2013 at 2:17 pm
    How do you want the 50fps version to look: repeated frames, interpolated frames, interlaced? Placing a 25fps clip into a 50fps sequence will automatically create repeated frames.
  • John Mark
    September 27, 2013 at 2:32 pm
    Im not quit sure, first time converting a video clip to a higher frame-rate. I just want it to suit 720, 50p. Would interpolated frames be best?
  • Ivan Myles
    September 27, 2013 at 3:28 pm
    Yes, but you will need to use After Effects. Do you have access to it?
  • John Mark
    September 28, 2013 at 12:12 am
    Yes. After Effects CS6.
  • Ivan Myles
    September 28, 2013 at 2:59 am
    Take a look at Time Warp and Frame Blending with pixel motion. You will have to judge whether it is appropriate for your particular circumstance.
