Activity Forums Apple Final Cut Pro Best way to contact Apple to request features and fix issues?
  • Best way to contact Apple to request features and fix issues?
    Posted by Matt Wilson on May 2, 2017 at 3:50 pm
    Does anyone know the best way to contact Apple to request features and fix issues?
    (Apparently when using Audio keyframes for volume, other than original 2 fade handles, you can only get a S-curve. There’s no choice for linear. So I want to request adding linear curve option.)
    Matt
    Matt Wilson replied 9 years, 4 months ago 3 Members · 4 Replies
  • Doug Metz
    May 2, 2017 at 4:49 pm
    From the Final Cut Pro menu (next to the ), select ‘Provide Final Cut Pro Feedback…’
    After reading your previous thread, I’ve made this request as well.
    FWIW, if you really -need- to have a linear fade, you can blade the clip and apply an Audio-Only transition which provides the options.
    Doug Metz
    Anode
  • Matt Wilson
    May 2, 2017 at 7:38 pm
    Thanks Doug. Will send the feedback to Apple today. Yeah the blade tool is an option, but if I end up using 3 or 4 keyframes in a clip, my clip might be cut up into multiple smaller clips, and since I’m sending to Audition, and then to Resolve, I didn’t want my clips cut up like that.
    Matt
  • Noah Kadner
    May 2, 2017 at 7:42 pm
  • Matt Wilson
    May 2, 2017 at 9:49 pm
    Just read article – good advice/tips.
