Activity Forums Maxon Cinema 4D best way to bake subdivided displacement map in material to geometry?
  • best way to bake subdivided displacement map in material to geometry?
    Posted by Anna Hahn on April 11, 2021 at 1:36 pm
    Hello!
    Could anyone please recommend a way to bake subdivided displacement maps from a material into the geometry of the object so that it does not need to calculate the displacement map for each render?
    Jim Scott replied 5 years, 4 months ago 2 Members · 1 Reply
  • Jim Scott
    April 11, 2021 at 5:19 pm
    The only way I can think of would be to use a displacer deformer and load your material into its “Shader” parameter, and then use the “Current State to Object” command. Make sure you have plenty of subdivisions in your object to get good detail. I don’t know how much it will change the render time, but it may be worth trying.
