Activity Forums Adobe After Effects best way to align clips from 1 to 10 playing clip 1 then 2 then 3 so on
  • best way to align clips from 1 to 10 playing clip 1 then 2 then 3 so on
    Posted by Hanna Dean on June 16, 2016 at 10:44 am
    in the timeline i will add 4 clips so all layers are on top of each other now how will i align each other so when i press plays clip from 1 to xxx
    its easy to do this manually on clips less then 4 but i have over 20 so doing it manually its not good.
    its there a quicker way to do this.
    Mike Kruft replied 10 years, 2 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    June 16, 2016 at 10:55 am
    Select the layers and use the sequence layers command.
  • Mike Kruft
    June 16, 2016 at 11:07 am
    To align layers quickly it is possible to use the shortcut keys [ and ] which ripples the layer and alt + [ and alt + ] which trims the layer.
    https://www,mediamaker.co.uk
