Activity Forums Adobe After Effects Best way to add time to composition?
  • Best way to add time to composition?
    Posted by Bali.cogerino on July 19, 2005 at 3:29 pm
    Hey!
    two very “novice” questions but I am stuck here:
    How to add time to an exiting compostion without expanding the duration of layers?
    Other question: is it possible to set the “original duration” of a layer after adding an object to a composition, opposed to use “stretch factor” option?
    Bali
    Chris Smith replied 21 years, 2 months ago 2 Members · 1 Reply
  • Chris Smith
    July 19, 2005 at 4:02 pm
    1. Go to Composition settings and change the duration of the comp.
    2. If it’s a solid, you can change the duration in the solid settings. If it’s imported footage, you can’t extend what frames aren’t there without time stretching.
    Chris Smith
    https://www.sugarfilmproduction.com
