Activity › Forums › Adobe After Effects › Best way for AE & Ppro to communicate in synch?
  • Best way for AE & Ppro to communicate in synch?
    Posted by Accountneedsrealnameupdate on August 8, 2007 at 12:50 am
    I have Ppro 1.5 and AE 6.5 standard. Wondering how in ‘synch’ they can be. For example I am creating a few custom transitions by overlaying a video clip, changing the opacity, blend mode, etc. Right now I just import the two clips, overlay the transition, export and re-import into Premiere. Is this the easiest way to do that? I know CS3 is all about using the programs in synch. What about my versions? Any easier way to create effects in AE and using them in premiere beside doing: import, create effect, save, reimport into Premiere?
    Roland R. kahlenberg replied 19 years, 1 month ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    August 8, 2007 at 12:59 pm
    With the versions that you have, you could also Copy the clips while you’re in Premiere. Head on to AE and paste into a Timeline. Do your magic there. Render and pick up the movie when you’re in Premiere.
    I prefer the render option when in AE cos not all things AE can be rendered in Premiere with 100% success.
    As long as I have a pre-AE sequence and a post-AE sequence in Premiere, I can rest assured that that is well and that there are backups in case things get nasty.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
