Activity Forums VEGAS Pro Best slowmo settings in Vegas
  • Best slowmo settings in Vegas
    Posted by Anders Fougner on April 14, 2009 at 5:24 pm
    Hi!
    I was just wondering about how to get best possible slowmo in Vegas.
    Before, i just smart resampling, but some of the shots would seem very blurry.. So now i’ve turned that off, but then the shots don’t “flow” that well.. I’ve read alot about interpolated frames, is this possible to do in vegas?
    I was also wondering about deinterlasing interlased footage for better slowmo, how is this done?
    Thanks alot!
    John Rofrano replied 17 years, 5 months ago 2 Members · 1 Reply
  • John Rofrano
    April 14, 2009 at 6:43 pm
    That’s what smart resample does and the blurry frames are the interpolated frames (which you turned off).
    If you change your project propertied to progressive, Vegas will deinterlace before it interpolates the frames. This may give you better results.
    You also might want to try Supersampling (look it up in the Help) This is normally use to smooth animation that has it’s frame rate changed but it may provide some benefit to your slo-mo video. (warning: supersampling increases render times dramatically)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
