Best settings to render 1920×1080
John Rofrano replied 11 years, 7 months ago 11 Members · 54 Replies
John Rofrano
April 21, 2011 at 2:14 pm[Lance Cagnolatti] “Is there a way in ARCH or/ and using another program say NERO 10 to create an ISO to upload to a server then have someone download it and burn it with the DVD ARCH menu intact for playback from a dvd player?”
Yea, one of the options on the burn menu of DVD Architect is to burn an ISO. It should be at the bottom of the dropdown list of DVD burners. Then anyone can burn the ISO to a DVD with any program they want.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Lance Cagnolatti
April 21, 2011 at 6:00 pmTHanks John,
So I would use the ISO Image Writer…
And it will save to my hard drive….
Then I can upload the files to a server…
Once my counterpart can download them, how would they burn it to a dvd so the menu would be there as I created it…
Sorry, I’m just trying to make sure I do it correctly on my end and my counter part knows what to do…
We have families back home that would be grateful to see these videos of my Troops… I just want to do this correctly…
Respectfully,
CPT Cag
John Rofrano
April 21, 2011 at 8:54 pm[Lance Cagnolatti] “So I would use the ISO Image Writer…”
Yes.
[Lance Cagnolatti] “And it will save to my hard drive….”
Yes.
[Lance Cagnolatti] “Then I can upload the files to a server…”
Yes.
[Lance Cagnolatti] “Once my counterpart can download them, how would they burn it to a dvd so the menu would be there as I created it… “
They can download the free ImgBurn utility and that will open an ISO file and burn it to DVD. They will, of course, need to have a DVD burner, which probably came with software anyway that already knows how to burn an ISO file.
~jr
David Clark
December 20, 2011 at 9:45 pmim new to this so how do u prepare an ISO file in DVD Architect and then burn it to DVD media with another program?
i got version 5.2 and dvd shrink
John Rofrano
December 21, 2011 at 2:31 pm[David Clark] “im new to this so how do u prepare an ISO file in DVD Architect and then burn it to DVD media with another program?”
When you get to select the burn parameters in DVD Architect, select ISO Image Writer from the Device drop down. This will create an ISO file. Like this:
Then use a program like ImgBurn (or any other burning program you like) to burn the ISO file to a disc.
~jr
David Clark
December 21, 2011 at 6:03 pmwill this still work if my project is using 7.2gb and im trying to place it on a regular 4.7gb disc?
John Rofrano
December 21, 2011 at 7:56 pm[David Clark] “will this still work if my project is using 7.2gb and im trying to place it on a regular 4.7gb disc?”
No. Your project cannot be larger than the size of a DVD.
~jr
Kira Pogge
January 12, 2013 at 4:36 pmThis message was very helpful – thanks to both of you for bringing up the topic and the great answer.
I do have one follow up question. I’m currently also rendering a video to be used and shown on a DVD and when I utilize the DVD Architect NTSC Widescreen video stream template it automatically changes my resolution to 480?… is that correct?
When I do try to customize the template so that it is 1920×1080 I receive and error message. Any advice would be greatly appreciated. Thanks so much for your time and help! 🙂
Kira
When you reach for the stars all you get are the stars, but we found a whole new spin. If you reach for the heavens you get the stars thrown in.
John Rofrano
January 12, 2013 at 4:51 pm[Kira Pogge] ” I’m currently also rendering a video to be used and shown on a DVD and when I utilize the DVD Architect NTSC Widescreen video stream template it automatically changes my resolution to 480?… is that correct?”
Yes, NTSC DVD Widescreen is 720×480 PAR 1.2121.
[Kira Pogge] “When I do try to customize the template so that it is 1920×1080 I receive and error message. Any advice would be greatly appreciated. Thanks so much for your time and help! 🙂 “
That’s because DVD’s are SD not HD. As my previous answer said, you can’t put HD on an NTSC DVD.
~jr
Kira Pogge
January 12, 2013 at 4:59 pmThanks John – much appreciated! I do understand now about SD on a DVD – good to know.
Have a nice rest of the weekend,
Kira
