Activity Forums Apple Final Cut Pro Legacy Best settings for shooting and importing HDV and DVCPROHD footage into FCP
  • Best settings for shooting and importing HDV and DVCPROHD footage into FCP
    Posted by Eduardo Frade miranda on May 5, 2009 at 2:36 pm
    Hello,
    I will edit a doc in FCP with HDV and DVCPROHD footage of a Z1 and HVX200 cameras. I know it should be better to use a single codec but thats what I got from the client. So I would like some suggestions about camera setups (Z1 and HVX200), and how i should import the footage into FCP. So the questions are:
    What are the best setups for the Z1 and the HVX200 footage to get along in FCP? 1080i? (I can talk with the crew at this point)
    Should I convert everything to Prores and start working with that? Or Just the HDV to DVCPROHD? (It will be color corrected in Color)
    My guess is, shot everything at 1080i and work with Prores, but I would like to be sure before start.
    Thanks in advance, and sorry about any misspelling in English.
    Eduardo.
    Eduardo Frade miranda replied 17 years, 4 months ago 3 Members · 4 Replies
  • Russell Lasson
    May 5, 2009 at 2:45 pm
    [Eduardo Frade Miranda] “My guess is, shot everything at 1080i and work with Prores, but I would like to be sure before start. “
    I think you’d be happy with this workflow and it will maintain the quality better than if you choose to convert HDV to DVCPROHD or the other way around.
    -Russ
    Russell Lasson
    Universal Post
    Ridgeline Digital Cinema Mastering
    Salt Lake City, UT
  • Eduardo Frade miranda
    May 5, 2009 at 4:09 pm
    Thanks Russel, I will do that. Is there any more catches with the camera setups or just tell the crew 1080i is good to go? (since I am not a cinematographer)
    thanks again,
    Eduardo
  • John Fishback
    May 5, 2009 at 4:28 pm
    Be sure to decide on a frame rate and use the same one on both shoots. The DP will probably have the most input on this, but your delivery specs might call for a specific rate.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
    May 5, 2009 at 4:42 pm
    Thanks John,
    I will talk with the DP about the possibilities. The doc will be distributed in DVD.
    Thanks a lot folks,
    Eduardo
