Activity Forums Adobe Premiere Pro Best settings for high quality video output
  • Best settings for high quality video output
    Posted by Bruce Pool on May 8, 2008 at 3:04 am
    I want to import my DV video into Adobe Premier Pro (on PC) and need to know what the best, highest quality settings I need tgo enter to output the very best high quality finished product. I don’t care how large the file is.
    Because I’m in New Zealand should I select PAL even though the DVDs I will output don’t seem to matter if PAL or NTSC.
    Bruce
    Dan Browne replied 18 years, 4 months ago 3 Members · 2 Replies
  • Harm Millaard
    May 8, 2008 at 11:19 am
    The golden rule of video editing: AVOID format conversions like the plague.
    If you shot in PAL, keep it PAL, if you shot NTSC, keep it NTSC.
    If you shot DV, keep it in DV until you have finalized your editing. Only then convert to MPEG2-DVD for final delivery.
    Harm Millaard
  • Dan Browne
    May 9, 2008 at 7:49 am
    What are you outputting from? for the highest quality and best compatability I would suggest if possible to capture actually using Premiere Pro. Im in NZ too, and really PAL, in my mind, is a superior format, and its the one NZ uses. AVI is premieres favourite format, just AVI uncompressed footage. Another thing is don’t try doing a software conversion from PAL to NTSC, it will never look good, always do it with hardware. And unless you need to show it to some Americans, always stay with PAL 😀
    Dan Browne
    Hawkes Bay, New Zealand
    Cloud South Films
    http://www.cloudsouthfilms.co.nz
