Activity Forums Adobe Premiere Pro Best Settings for 600d / T3i footage in Premier Pro CS5?
  • Best Settings for 600d / T3i footage in Premier Pro CS5?
    Posted by Guy Smith on October 21, 2011 at 6:10 am
    Hello everyone, just testing out the T3i, so far very impressed, really these little things are a real milestone along with the DVX100! I was hoping someone would know what settings I should use in CS5 to start a new project. I’ll actually be bringing in all the footage from After Effects as a project file. (After effects has a basic 1920×1080 24fps setup that happens when I drag the 600d files into it – actually it sets up as 23.97 which is wierd becuase I’m sure it shoots in 24?! anyways . . ) thankyou
    Guy
    Guy Smith replied 14 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    October 21, 2011 at 5:53 pm
    Those cameras shoot 24p…which runs at 23.98. Nearly ALL VIDEO at 24p is 23.98. Straight up 24fps is FILM…and some high end tapeless format cameras. But the rest is 23.98…and that is what it SHOULD be.
    Shane
  • Guy Smith
    October 22, 2011 at 1:58 am
    hi, thanks Shane, I’ve set it to the 23 frame rate, you’ve saved me a lot of hassle – I was getting a ‘frame rate mismatch’ message now and again! Would you know the other settings to use please? I’ve made a preset with 1920×1080 and ‘square pixels’.
