Activity Forums Adobe Premiere Pro best sequence settings for 1080i 24PA footage in Premiere Pro CC
  • best sequence settings for 1080i 24PA footage in Premiere Pro CC
    Posted by Drew Sagona on March 9, 2016 at 5:47 pm
    Hi all
    I’ve shot some footage from a Panasonic HPX 170 in the format 1080i 24PA on a P2 card. My footage info is as follows:
    Type: MXF
    File Size: 409.73 MB
    Image Size: 1280 x 1080
    Frame Rate: 29.97 (24p)
    Source Audio Format: 48000 Hz – 16 bit – 4 channels
    Project Audio Format: 48000 Hz – 32 bit floating point – 4 channels
    Total Duration: 00:00:29:20
    Pixel Aspect Ratio: 1.5
    MXF File details:
    Wrapper type: MXF-OP Atom (type: N Tracks 1 SourceClip)
    File generated by: Panasonic, P2 (2.0)
    DV 100
    P2 Metadata details:
    UserClipName: 060A2B340101010501010D43130000004526B5F1487405C30080458228E5F433
    DataSource: SHOOTING
    Access:
    CreationDate: 2016-03-02T09:28:02+10:00
    LastUpdateDate: 2016-03-02T09:28:32+10:00
    Device:
    Manufacturer: Panasonic
    SerialNo.: E9TCA0061
    ModelName: AG-HPX170P
    I’m wanting to know what to set my sequence settings to before beginning editing in Premiere Pro CC 2015. Any help would be most appreciated.
    Drew
    Chris Wright replied 10 years, 6 months ago 4 Members · 5 Replies
  • David Roth weiss
    March 9, 2016 at 6:38 pm
    Drop a clip on a new timeline and let Premiere match the clip.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Shane Ross
    March 9, 2016 at 6:58 pm
    This also begs the question…do you want a 29.97 timeline…basically the 24p LOOK, but running interlaced at 29.97…or are you wanting a 23.98 progressive timeline? With pulldown removed… What are your master delivery needs?
    Shane
    Little Frog Post
  • Drew Sagona
    March 9, 2016 at 7:09 pm
    Shane,
    My master delivery needs will be exporting for JW Player. I dropped the footage into a new sequence and changed the sequence settings to match the clips. I also made sure that pull down was removed in the interpret footage option so that my footage would be progressive. However when I add text over the clip the footage seems to have a slightly blurry line that runs through the middle and I’m trying to figure out why. Any help would be appreciated.
    Drew
  • Drew Sagona
    March 9, 2016 at 7:52 pm
    Also when I render selection, the footage also seems slightly blurred, but when I pause it it is crisp again. Any help understanding this would be appreciated as well.
  • Chris Wright
    March 9, 2016 at 8:54 pm
    playback is bilinear, paused is lanzcoz in software mode.
