Activity Forums Apple Final Cut Pro Legacy Best Scrolling Credits Settings
  • Best Scrolling Credits Settings
    Posted by Adam Schoales on December 9, 2008 at 4:21 pm
    I posted a previous topic about creating scrolling credits here:
    https://forums.creativecow.net/readpost/8/1014572
    In that post we determined that my best solution would be to create the type layout in photosho, and then bring that into final cut where I would animate my scroll.
    However I was wondering if anyone had some thoughts on the best settings…
    I realize there’s no standard “recipe”, but if people had any tips whatsoever that’d be really helpful.
    From what I’ve gathered I would animate the Y-axis in the motion panel and then add a slight motion blur (of course I have no idea how much of one…
    Thanks in advance everyone!
    Adam Schoales replied 17 years, 9 months ago 4 Members · 6 Replies
  • Chris Poisson
    December 10, 2008 at 3:38 pm
    Hi Adam,
    One of the things I don’t hate about Boris is it’s Title Crawl. It works really, really well. Buttery smooth and very adjustable.
    You will still have control over type style, spacing, kerning etc., a huge advantage over a PS file.
    TIP: add returns at the end of the roll to make the text go off screen.
    Have a wonderful day.
  • Adam Schoales
    December 10, 2008 at 5:04 pm
    the problem is i have to combine left justification with centre justification, and boris wont let me do that — nor will it let me have the credits the length I want…
    otherwise I would use it in a heartbeat (because as you say, it’s fantastic!)
  • David Bogie
    December 10, 2008 at 6:48 pm
    I had not understood that Boris was a viable tool for you. This makes it simple if not direct. You want to build two separate movies that site next to each other and move in sync.
    bogiesan
  • Adam Schoales
    December 10, 2008 at 9:28 pm
    okay but again… the problem is the combination of justification (I cannot have both centered and left justified) and I also can’t stretch it to be the right length (it has a limit).
  • Ed Grogan
    December 11, 2008 at 3:07 pm
    You can do what you want. I do it in Boris all the time.
    see https://www.borisfx.com/tutorials/CreditRoll.php
    Ed
  • Adam Schoales
    December 11, 2008 at 5:23 pm
    ahh thank you! that should solve the justification problem. doesn’t quite fix the length issue but I can fudge it slightly…
