Activity › Forums › Avid Media Composer › Best Quicktime format from FCP to Adrenaline?
Posted by Bob Roberts on November 28, 2006 at 5:29 amI have to send an uncompressed Quicktime file from Final Cut Pro to an Adrenaline suite. What is the best codec to use?
Thanks in advance.
Oliver Peters replied 19 years, 10 months ago 4 Members · 4 Replies -
John Pale
November 28, 2006 at 6:38 amjust export from FCP (quicktime conversion) using the Animation codec at full quality. Animation is a standard Quicktime Codec available to all systems.
The Avid Quicktime Codec, will give you a faster import into the Adrenaline, BUT installing the Avid Quicktime Codec on your FCP system (if you are running 5.1.2) may cause FCP to unexpectedly quit on startup, so I would avoid it unless it is specifically required.
The Apple Uncompressed 8 and 10 bit Codecs are installed by Final Cut Pro only, so they will not be available on the Adrenaline system.
Wes Plate
November 28, 2006 at 4:30 pmYou set that in the import dialog.
— Wes Plate
Automatic Duck -
Oliver Peters
November 29, 2006 at 5:16 pmOr, if you have SDI out of the FCP system, simply run FCP out to MCA in and capture on-the-fly in real time.
Sincerely,
OliverOliver Peters
Post-Production & Interactive Media
Orlando, FL
http://www.oliverpeters.com
