Activity Forums Adobe After Effects Best quality DVD render
  • Best quality DVD render
    Posted by Dan Brown on November 15, 2014 at 5:10 am
    I create my compositions at 1920×1080 since that is what my camera outputs in AVCHD format at 60fps. When I render I’m resizing down to 720×405. I have some basic rendering questions that I can’t quite figure out on my own.
    1) Should I forget about the ratio and force 720×480?
    2) What file type will includes sound and not lose too much quality?
    Previous renders showed AVIs and MOV files are too large. H.264 creates a separate .m4v file which I don’t think will work for putting it on a DVD. FLV is the only thing I’ve found that is respectable in size and includes sound. If anyone can share their preferred render settings for DVD clips I’d be so relieved. Cause each render is another hours wait. Thanks in advance
    Roland R. kahlenberg replied 11 years, 10 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    November 16, 2014 at 11:32 am
    DVDs require MPEG-2s. There are presets in the Output Module that allow you to select an ideal (though not necessarily optimal) setting.
    DVD authoring apps require strict adherence to DVD standards. So, you do need to stick with 720×480. You should scale to fit the height of 480. Your width will be larger than 720. YOu can center the composition as it is or re-position it on the x-axis.
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
