Activity Forums VEGAS Pro Best pulldown? oops Darn!
  • Best pulldown? oops Darn!
    Posted by Brad Leigh on January 24, 2013 at 9:14 pm
    Hi
    While editing my project a mixture of HD animation and HD shot footage I started to notice awful artifacts in my preview window. Searched through this fourm’s posts via interlacing. Well I found that my animation program at some point in setting up batch rendering switched back to it’s default of 30 fps. My project is 29.97 Animations use the Quicktime animation codec. I found if I select a clip in the timeline and set playback speed to .999 and turn off re-sample everything looks and acts great. So I went to the media bin right clicked all the animation media and some were 30 fps, but the frame rate is greyed out so I can’t change that and in the media bin there is no speed select window. So it seems the only fix is to select each clip in the time line and change speed, and hope the clip doesn’t fall short in the time line.
    Question
    Is there a way to pulldown a piece of Media in the Media Bin so I don’t have to do it on every segment in the time line, (and hope I don’t miss one and get crazy artifacts)
    Brad
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 10
    Brad Leigh replied 13 years, 8 months ago 1 Member · 1 Reply
  • Brad Leigh
    January 24, 2013 at 11:03 pm
    Vegas Pro 12
    Just fixed my tag.
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
