Activity Forums Adobe Premiere Pro Best preset setting for C-300?
  • Best preset setting for C-300?
    Posted by Kevin Allar on August 6, 2012 at 9:26 pm
    Can someone tell me the best settings to set-up a project for the Canon C-300, 1080p, at 29.97? Been using the DSLR presets but not sure if that’s the best way to go.
    Kevin Allar
    Phil Balsdon replied 14 years, 1 month ago 3 Members · 2 Replies
  • Angelo Lorenzo
    August 6, 2012 at 10:54 pm
    The C300 uses the same format as other Canon XF camcorders. The presets don’t really change anything in terms of performance (at least I assume not, they’re both mpeg based camera codecs), so if it matches the framerate/size of your footage you’re good to go. Both the DSLR and Canon XF presets do preview rendering in MPEG I-frame.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Phil Balsdon
    August 7, 2012 at 2:52 am
    You’ll find it under “Canon XF MPEG2” in the “Sequence Presets” menu.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://philming.com.au
    https://www.steadi-onfilms.com.au/
