Activity Forums Adobe Premiere Pro Best Premiere Pro CC workflow for a “Best-Of” episode
  • Best Premiere Pro CC workflow for a “Best-Of” episode
    Posted by Lars kristian Flemmen on April 21, 2015 at 12:10 pm
    We are twisting our brains trying to figure out the best workflow for a “best-of” episode for a episodic television show, edited on premiere pro CC 2014.
    The show consists of ten episodes (22 min pr ep, 50-60 shooting days, 5+ TB of material) and for the “best of” and the “behind the scenes” episodes, we want to import, reedit, scroll through material from all the previous episodes.
    Simplest workflow, as far as we can tell:
    Opening the different projects in the media browser, or multiple media browser windows, copying and pasting the parts we want into the “best-of” project or sequence.
    Simple. But. When we do that, we are not able to match-frame the material once were back in the “best-of” sequence. That is, every now and then it works, regardless of wether the material is present in the best-of project or not. Sometimes I can find the material in the project (shift+f) but not match frame it.
    Also, when copying parts of a sequence into the “best-of”, you’d think the relevant material would be copied as well. Sometimes it is, sometimes it’s not. Sometimes a few files are copied.
    Has anyone done a project like this, and what was you workflow of choice?
    James Strawn replied 11 years, 5 months ago 2 Members · 1 Reply
  • James Strawn
    April 21, 2015 at 10:54 pm
    It’s hard to day without being able to see how your previous episode project were set up. I seems like the ‘Multiple Project Workflow’ features from CC 2014.1 were made with needs like yours in mind. However, if that’s not exactly working for you, it seems like a nested sequence workflow would be the easiest. If you can straight-forwardly grab the sequence assets you want from those older projects, then it;’s just a matter of making a new sequence for each and nesting them into a master sequence with whatever footage is going to be tying it all together. You should have no problem matching frames either direction as long as you’re always in the same sequence.
    I’ll be thinking of other possible workflows in case that doesn’t work for you either.
