Activity › Forums › Adobe After Effects › Best photo frame size for After Effects template
  • Best photo frame size for After Effects template
    Posted by Jeff Openshaw on October 28, 2013 at 8:44 pm
    I am making a template in AE where photos spread out on a table will rise up to almost fill the screen. I am using position and scaling to get them in position and then disappear with opacity, the pictures are not 3d, just the background so I can use lights. I am making precomps in the main comp for the placeholders. People sometimes pull pictures off the internet that are low resolution, so my question is how small can I make the placeholder and still get it to scale in the main comp without losing quality of the picture?
    Jeff Openshaw replied 12 years, 11 months ago 2 Members · 4 Replies
  • Jeff Openshaw
    October 28, 2013 at 8:46 pm
    I forgot to mention the comp is 1920×1080.
  • William Meese
    October 29, 2013 at 4:29 pm
    Not sure I understand your question: as soon as you’re scaling non-vector items above 100%, the apparent quality may go down. So make your precomps 1080 also, or whatever size allows you to keep their scaling below 100% when at their largest. Then scale the source picture _within the precomp_ to fit. This will not improve low-rez stills — is that your intent?
    Again, not sure I understand your question. Can you rephrase?
  • Jeff Openshaw
    October 29, 2013 at 6:40 pm
    That answered my question perfectly. I’ll make sure the placeholder never scales above 100 percent in the main comp. Thanks!
  • Jeff Openshaw
    October 29, 2013 at 6:55 pm
    My plan is to make 2 placeholders that can be changed out as needed for either portrait or landscape. The landscape photos will not fill the whole 1920×1080 at their final position, so I need to find a size that works good for the portrait and landscape, without changing the keyframes in the main comp. It won’t be perfect but it will give people a choice in case they have too many of one kind, portrait or landscape photos. This template will be used as a memorial video so old photos will need to be scanned for higher resolution as I see it depending on their aspect ratio. Any thoughts on this would be great.
