Activity › Forums › Apple Final Cut Pro Legacy › Best path from 720p/60 to SD DVD
Posted by Fred Grossberg on July 18, 2006 at 10:28 pmOh great seers:
I have a 720p/60 sequence that I’d like to put on a simple standard-def DVD using DVD Studio Pro. To avoid the gamma and saturation problems I’ve been reading about in this forum, I’d like to do a good downconvert from HD to SD and then encode to mpeg-2. I’d rather not use Compressor, for all the reasons I’ve been reading about here. I do have a Kona 3 card, and I thought I might somehow use the Kona to get an SD version of the sequence on my timeline and then export a reference movie and encode to mpeg-2 within DVD Studio Pro.
A. What do you think of this path?
B. Exactly how would I downconvert using the Kona?
C. How do I handle the audio?
Sorry to be so dumb, but I’d like the end result to look good and I’m pretty new at this stuff. I know just enough to think that this could end up looking crummy if I took the obvious Compressor route. Many thanks –FredFred Grossberg replied 20 years, 1 month ago 5 Members · 8 Replies -
Fred Grossberg
July 19, 2006 at 2:53 pmThanks for your reply. I have an SD deck but no other Final Cut system. I’m trying to avoid going back out to tape because I hear Final Cut messes with the gamma when you print to tape.
Walter Biscardi
July 19, 2006 at 2:58 pm[Fred Grossberg] “I’m trying to avoid going back out to tape because I hear Final Cut messes with the gamma when you print to tape.”
Who told you that? What FCP does, if you want it to, is raise the blacks from 0 (HD) to 7.5 (SD), but you have total control over that.
Walter Biscardi, Jr.
https://www.biscardicreative.com“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Fred Grossberg
July 19, 2006 at 3:20 pmWalter:
I got it from this post:
Dennis Lisonbee on 2006-05-30 03:56:27
This is a little late, but this is an issue I was faced with two years ago when using compressor for a High Def show. The Director of Photography was VERY” upset with the blacks and the gamma when we did our test DVD. We all went round and round with this and finally discovered that when the high def goes to tape it changes the gamma and black levels because in the MAC way of doing things FCP changes the gamma and black levels to match the monitor so that we see it correctly. When it goes to tape those levels are automatically changed. When it goes to DVD IT IS NOT CHANGED and as a result when you play it back on a DVD player and Monitor the gamma and black levels can look very bad. It is even worse with High Def than DV. Only people that know what they are watching for will notice the shift in DV to DVD. After my colorist did the mathematical calculation he changed the gamma and blacks in Final Cut Pro, compressed it using compressor and DVD looks great! I’m surprised that after several years someone else discovered this![Back to Fred] Admittedly I couldn’t quite understand this post. All I’m trying to do is get a decent looking downconverted version of my 720p/60 sequence onto DVD. Could you please quickly tell me the best way of doing this? Many thanks
Jeremy Garchow
July 19, 2006 at 3:26 pmYou can use your Kona to do a hardware downconvert to tape. What kind of deck do you have, if it’s DV I wouldn’t bother.
For what it’s worth, I have used compressor to downconvert from HD to SD MPEG-2 for DVD and it looks fine. Have you done a test?
Jeremy
Chris Poisson
July 19, 2006 at 5:10 pmFred,
Without a preview on an NTSC monitor, yes, there can be some gamma and saturation issues with Compressor, but a little trial and error with the filters can make it pretty darn good. You can do short samples so it doesn’t take too much time.
Have a wonderful day.
Charles Caillouet
C. How do I handle the audio?Fred,
You are addressing several issues and you need to separate them out to get good results.
First, there is a difference among down-converters and they change with each new revision.
I have found in the past that the scaling in FCP, at least for interlace originals (you have progressive), is not that great. I have found that Motion is better. I haven’t found all the switches in Motion, but so far, Affter Effects offers the most options in dealing with interlace and changing frame rates, if you have to go there. There are other apps that i haven’t tried that apparently do even better.Second, the color encoding equations for NTSC and HD are different. You may find that the luma reproduction is fine but the luma component of saturated colors is different for the two. If you want to see this, take 100% bars from each and look at the difference in the luma steps from white through yellow, on down to blue and then black. If the software doesn’t properly convert between the two, you will get dissapointing results.
Third, these problems also can exist between apps in the same format. There seems to be a disagreement between some apps on what format Quicktime movies arrive in. I don’t know if it because of incorrect tags or inadequate data. I have problems moving edited clips from FCP to Sorenson Squeeze and even some minor ones when i go to the Main Concepts encoder. These can be slight gamma changes to level changes large enough to cause clipping. I have custom filters in FCP to pull levels down and corresponding ones in Sorenson to pull them back up. This can’t be good for signal to noise.
I have several test signals (stairsteps and color bars) that i run through my process and check at the end to see what is working and what is not. Then i compare the actual material in a short test to see if the levels are the same. On top of that, you have to be careful where you monitor because different apps, again, interpret decoded results differently. Obviously, the best approach is to use the same decoder that will be used at the destination, and that is a problem if it won’t be decoded until a consumer gets it.
I don’t know about using the Kona for file-based conversion. Gary Adcock should be able to address that. He is usually on this list.
Audio is another headache. I mux my MPEG2 streams with the Windows app “TransMux” from Pixeltools so that i can include Dolby Digital (AC3) streams from Compressor (was APack). The Sorenson Mux does not deal with AC3 and some of the other options are pretty messy. MainConcepts for the Mac is also not helpful for AC3. If you try to encode AC3 with an older version using APack, be sure to turn off one of your dual processors or it will likely crash.
My solution has been to try different apps and settle on the workflow that gives me the least grief with the best results for each project. The last one that i did used FCP for prep, Motion for down conversion, mcoder for encoding, Compressor for AC3 and TransMux for multiplexing. If you need to go to a standard DVD, then going through DVD Studio Pro should work, but i would compare the FCP and Motion conversion before you decide. The new version of FCP may be better.
hope this helps…
crc
Fred Grossberg
July 19, 2006 at 8:35 pmC.R. Thanks a lot for your lengthy reply. I can see this is not a simple matter. The irony is that when I told my client it might take a day or two to get this done, she said, “What?? All you have to do is burn a DVD. How hard can that be?”
