Activity › Forums › Apple Final Cut Pro Legacy › Best output and burn workflow for XDCAM 1080i60
  • Best output and burn workflow for XDCAM 1080i60
    Posted by John Henion on September 19, 2009 at 3:08 am
    Hi there,
    I just finished up a project with XDCAM 1080i60 footage and the client wants it burned to a dvd. I don’t have an HD DVD burner, so I figured I would just export as quicktime and burn SD using iMovie…WRONG! As I learned later right here on creative cow, iDVD doesn’t play nice with HD unless compessed with Intermediate Codec…
    So taking some advice from threads on here I exported to Mpeg-2 via compressor to be used in DVD Studio Pro 4. Two issues arose:
    1. using the 90 minute high quality mpeg2 encode in compressor, my output file has a bad case of combing the effect (the lines of resolution on motions). Question: how do I get rid of this nasty effect in my output file?
    2. In DVD Studio Pro 4 I can’t seem to be able to set the files to play in 16:9 widescreen…Question: Assuming that i’m limited by my hardware – an SD DVD burner, is there away for my source files to retain there native 16×9 aspect, or will I have to settle with pan & scan?
    Thanks for you input!
    John
    John Henion replied 17 years ago 2 Members · 2 Replies
  • Rafael Amador
    September 21, 2009 at 10:57 am
    [john henion] “1. using the 90 minute high quality mpeg2 encode in compressor, my output file has a bad case of combing the effect (the lines of resolution on motions). Question: how do I get rid of this nasty effect in my output file?”
    Duplicate the Preset, and in the “General” tab, check NTSC, 16×9, Upper first.
    You should also set the “Frame Control: ON” and “Resize filter: Better”.
    This will helps you to get a better downscaled picture.
    [john henion] ” In DVD Studio Pro 4 I can’t seem to be able to set the files to play in 16:9 widescreen…Question: Assuming that i’m limited by my hardware – an SD DVD burner, is there away for my source files to retain there native 16×9 aspect, or will I have to settle with pan & scan? “
    You must identify the file as 4×3 or 16×9.
    Sorry but I haven’t had never clear in which cases to choose “Pan&Scan”, “16×9 Letterboxed”, etc.
    rafael
    http://www.nagavideo.com
  • John Henion
    September 22, 2009 at 6:57 pm
    Rafael – thanks a million. Problems resolved.
