Activity Forums VEGAS Pro Best .mov Compression for high quality but not HUGE file size?
  • Best .mov Compression for high quality but not HUGE file size?
    Posted by Hannah Jacobs on May 30, 2009 at 9:07 pm
    I purchased a lower 3rd graphic in .mov format that’s 18mb. (It needs to be chroma keyed to use.) I made a simple edit to it in Vegas Pro 8 (to make it longer before the animation closes the lower 3rd at the end of the clip) and I’m trying to re-save it.
    Uncompressed, the .mov 8-second clip w/no audio is 370mb.
    Compressed, the largest file size I’ve gotten is 3mb and there are compressed artifacts that look bad when chroma keyed.
    There’s got to be a happy medium. How can I save this file to good quality (no artifacts) and keep the file size under, say, 50mb?
    It doesn’t have to be .mov, I just need to be able to chroma key it in the video.
    Side note: There’s got to be more leeway on compression/filesize using .mov, but I tried several variables which didn’t change much.
    John Rofrano replied 17 years, 3 months ago 2 Members · 1 Reply
