Activity Forums Adobe After Effects Best / Most commonly-used video file
  • Best / Most commonly-used video file
    Posted by Graham Quince on May 13, 2006 at 10:48 am
    Hi guys
    I’m creating an EPK DVD for an entertainer friend of mine. We would like to to include his video advert in the DVD-Rom section, so that if your entertainment manager booked him and then asked you to play his advert on your company’s screens, you wouldn’t have to go to the trouble of ripping his DVD (or contacting him for a clean version) just to get the video.
    If you were in this position, what file format would you want? (About 60 seconds of NTSC video with music and speech)
    Graham
    https://www.qcit.co.uk – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
    Graham Quince replied 20 years, 4 months ago 3 Members · 4 Replies
  • Andrew Yoole
    May 13, 2006 at 2:23 pm
    Unfortunately there’s no simple way to make one file for all purposes. But for maximum compatibility I’d probably choose MPEG1, which will play natively on any version of Windows since Win98, and any form of Mac with QT Version 4 or later.
  • Graham Quince
    May 15, 2006 at 8:56 am
    Thanks for the reply Andrew
    I’ve never really used Mpeg1, but I have tried to use Mpeg2 – which screws up A/V sychronisation if you try to edit with it – highly likely if someone is wishing to convert the format. Does Mpeg1 have these compression issues?
    Graham
  • Steve Roberts
    May 15, 2006 at 1:36 pm
    There is no video file format or codec for all purposes. Codecs that play well on most machines (and the web) don’t necessarily edit well. The idea is to create a video file that has been compressed for a specific purpose, such as:
    – layoff to tape (e.g. Blackmagic or DV)
    – high-quality for eventual transfer to an editing station (e.g. Animation or Microcosm)
    – space-saving archiving (Photo-JPEG)
    – playback on hard drives (Photo-JPEG, WMV or others)
    – playback over the web (H.264, Sorenson Pro, WMV)
    – quick client previews (WMV or MPEG-1)
    – playback on standard set-top DVDs (MPEG-2)
    – transfer to a specific editing station for easy editing (Avid Meridien or DV)
    So … for now, I recommend you create a high-quality file for archiving using the Quicktime Photo-JPEG codec, maybe at about 89% quality. (if you have a lot of space, use the Quicktime Animation codec.) Then, when you know the specific output needs, you can use AE, Sorenson Squeeze or Apple’s Compressor to create the needed file, possibly in one of these delivery formats if you like:
    – MPEG-1 for hard drive/web format
    – WMV for web format
    – Avid meridien if the editor has an Avid
    – DV if the editor edits on DV
    – MPEG-2 for DVD
    Does that help? If you need more info, you might want to check out the Compression Techniques COW.
  • Graham Quince
    May 15, 2006 at 2:37 pm
    Thanks Steve
    Yeah I think that clears it up. Seeing as it’s for the DVD-Rom element, I think I’m going to try and provide Mpeg-1 as Andrew suggested with the Quicktime Animation / Quicktime Photo-JPEG codec depending on file size. His current EPK dvd is only 20 minutes, so I’m going to have lots of room.
    Many thanks
    Graham
