Activity › Forums › Panasonic Cameras › BEST method for software down conversion
  • BEST method for software down conversion
    Posted by Christopher S. johnson on May 2, 2005 at 10:01 pm
    What is the best method for *software* down conversion from DVCPRO HD to SD DV? I have a Mac, Final Cut Pro, and Compressor.
    My first thought is to just use Batch Export in Final Cut Pro. This keeps time code too right?
    -Christopher
    Walter Biscardi replied 21 years, 4 months ago 4 Members · 6 Replies
  • Scott Davis
    May 4, 2005 at 11:33 pm
    In my experience the software downconversions look terrible. I’ve tried both FCP and AE (AE’s being the slightly better looking downconversion). I’ve found that using a 1200A with SDI to a DV deck with SDI yields the best results. You can have the TC synched so that if you ever want to master from the HD you can. Downside is the cost of the dubs.
    Scott Davis
  • Christopher S. johnson
    May 4, 2005 at 11:49 pm
    Thanks for the good info, I just met the FCP team from Apple last night. They said the new version of Compressor coming with FCP5 would do “very high-end” conversions, both format like PAL to NTSC and HD down or up conversion. this was sort of an acknowledgment that it was not “High-end” before. They were very proud of the new conversion tool and mentioned it a number of times to make sure we understood that it was completely different now.
    -Christopher
  • Scott Davis
    May 5, 2005 at 11:32 pm
    If this is true; great. I still think hardware downconverisons will yield better and faster results than Compressor.
    Scott Davis
  • Jeremy Garchow
    May 7, 2005 at 7:05 am
    If yo have a G5, get yourself a Kona2 and bring the HD-SDI in to do a realtime down conversion to SD or DV or whatever you want. then all you have to do is set your settings up for HD, redigitize, and you are ready for your online.
    May 7, 2005 at 4:10 pm
    Yes, im familiar with the Kona and BM cards. I was wandering about software methods. I think the new version of Compressor coming out might do the trick.
    -Christopher
  • Walter Biscardi
    May 9, 2005 at 11:56 am
    [Christopher S. Johnson] “I think the new version of Compressor coming out might do the trick. “
    Depends on how much footage you have and how long you have to allow for the rendering. As noted above, the Kona and Decklink cards perform realtime downconvert and as an onwer of the Kona 2 I can tell you the quality is oustanding. The K2 now has on-board upconvert as well which looks very good too in case you have to mix SD with Varicam footage.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
