Activity › Forums › Adobe After Effects › Best method for masking unwanted thing?
Posted by Andrew Rabka on April 27, 2016 at 7:07 pmHello, my problem is the visible socket on the wall in background. Whole time it is covered, but in this particular moment women moved her’s head.
I tried two methods:
Clone stamping tool – but it requires work with every single frame
Roto brush tool (with added still image without socket on the wall in bottom layer) – the edge (hair) is unprecise and the final effect is poor.
Maybe I use those tools incorectly? Do you have any advice?
Stephen Smith replied 10 years, 4 months ago 3 Members · 4 Replies -
Kalleheikki Kannisto
April 29, 2016 at 8:23 am“Roto brush tool (with added still image without socket on the wall in bottom layer)”
is close to the answer. But a feathered animated mask instead of roto brush would give you a more controlled movement.
Stephen Smith
May 11, 2016 at 10:37 pmIf you decided to go the animated mask route I recommend you let AE try to track the mask for you. Create your mask and then right click on it. Choose “track mask” from the drop down menu. It actually works surprisingly well. I used it for some parts of this spot I did: https://vimeo.com/160269510
Stephen Smith
Check out my Vimeo page
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Andrew Rabka
May 12, 2016 at 1:45 pmIs there any smart tutorial how to do it? I can’t understand how to shape mask for more complicated things like hair. Every tut says about easy figures. Using the curves for shaping the mask, seems to be much harder than using rotobrush.
I’m thinking about correcting frame by frame, but exporting every frame to the photoshop and creating sequence in ae is quite inconvenient. Maybe it can be done direct in ae, like using clone tool? How set different “cloned points” for every frame?
Stephen Smith
May 12, 2016 at 2:37 pmFirst off, in the still grab her hair appears to be so thick it should work with the rotobrush. Here is a tutorial to watch on the Roto Brush: https://www.videocopilot.net/tutorials/alien_surface/ Skip to 16:35. Be sure to add a feather to the roto brush.
If you want to use the mask track all I can advise is what I have already said with the addition of make sure you add a feather to the mask.
Back before both of these tools where availableI did do stuff like this in photoshop and it never work. Because you are looking at each frame independently it bounces around to much once the images are stitched together.
I used a roto brush on the boy in this commercial: https://vimeo.com/76003006
Here is a before and after: https://vimeo.com/76622200
Stephen Smith
