Activity › Forums › Adobe After Effects › Best memory settings?
  • Tudor “ted” jelescu
    May 23, 2011 at 1:47 pm
    leave 1.5 GB for other apps and assign 2GB per processing core- do not be amazed if you get only 2 cores working though, even if the math does not add up.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Todd Kopriva
    May 23, 2011 at 2:45 pm
    That math does add up, though:
    8GB – 1.5GB for other applications leaves 6.5GB.
    The foreground process takes 1.2 x (RAM per rendering process) = 2.4GB.
    6.5GB – 2.4GB = 4.1GB.
    That 4.1 GB is enough for two background rendering processes.
    See this page for more information about recommended memory settings:
    https://blogs.adobe.com/toddkopriva/2010/10/please-try-recommended-memory-settings-for-after-effects-cs5-and-give-feedback.html
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
    May 23, 2011 at 4:49 pm
    I meant that at first glance it seems that you should be able to use 3 cores (2×2 + 1.5=5.5), if you do not take in consideration the other stuff Todd mentioned, but you got the details from the Adobe man himself.
    Tudor “Ted” Jelescu
    Senior VFX Artist
