Activity Forums Adobe After Effects Best Memory Cache settings for CS3?
  • Best Memory Cache settings for CS3?
    Posted by Milton Hockman on May 2, 2008 at 12:26 am
    what are the best memory cache settings for CS3 on intel imac 2.16 with 3GB ram?
    stock 120 max memory and 60 max ram cache takes 13 seconds to render 30 sec comp.
    120 max memory and 80 max ram caceh takes 9 secs.
    waht is the best to do? can i put the max memroy cache to 100?>
    Motion Graphics Artist and Non-Linear Editor
    Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more.
    Darby Edelen replied 18 years, 4 months ago 2 Members · 1 Reply
  • Darby Edelen
    May 2, 2008 at 12:31 am
    [milton hockman] “waht is the best to do? can i put the max memroy cache to 100?>”
    You can, but you shouldn’t. I wouldn’t recommend going above the 80% you already tried, if you go much higher you’ll significantly increase the chances of a render failing.
    Also, are you sure that setting it at 80% actually made it go faster? Have you tried doing the same thing in the opposite order (render with 80% first then go down to 60% and try it again)? AE may have just been reusing things it already cached in the first render for the second render.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
