Activity › Forums › Avid Media Composer › Best Mac to run Avid Composer on
  • Best Mac to run Avid Composer on
    Posted by Sarah Lauch on April 16, 2015 at 6:23 pm
    Hi. I am about to build out my own personal Avid. I would like dual monitors and will use a Mac. Anyone know the easiest way to do this and what Avid is best? Would it be best to have a tech come and build it out? I do have experience with all this technology. THANKS!
    Sarah Lauch replied 11 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    April 16, 2015 at 8:24 pm
    BEST? Well, the new MacPro tube will, as will the MacBook Pros…all the iMacs…MacMinis will. Not sure the new MacBook can…it’s processor is a mobile one (used in iphones). MacBook Air would barely cut it. So…the question is, what’s your budget?
    And you really only need a tech if you are going beyond simply installing the software onto a computer. If you want to add HDTV or broadcast monitor, you’ll need an IO device…either Avid or third party. And that’ll take a tech to set up, if you aren’t technically inclined.
    Shane
    Little Frog Post
  • Sarah Lauch
    April 16, 2015 at 8:31 pm
    AWESOME! thank you Shane!
