Activity Forums Adobe Premiere Pro Best Hardware monitoring option (PC)
  • Best Hardware monitoring option (PC)
    Posted by Adam Read on August 23, 2011 at 10:40 am
    Hi
    Running CS5. I was having lots of stability problems when using a Matrox MX02 mini so decided to ditch it. Problem I now have is that I can only run one GUI monitor as PP is now running in desktop mode with the 2nd monitor now displaying the programme picture.
    Stability is excellent, no crashes. However… I am seriously missing my 2 monitor set up + a ‘proper’ video output to monitor.
    Can anyone on the PC side comment on stability/experience with the offerings from Blackmagic or Kona? I do not want to go back to Matrox.
    Many Thanks
    ADAM READ
    Adam Read replied 15 years ago 2 Members · 2 Replies
  • Philip Imbrenda
    August 23, 2011 at 8:09 pm
    I also bought the Matrox Mini and at first I had problems with Adobe crashing(CS5.5), I have an HP Z400 with nvidia 4000 Graphics Card. The documentation on how to install the box was very poor, after a few calls to Matrox and then an hour later I had it up and running the the crashes started after that, I found that the nvidia drivers had to be updated, then I had no more crashes, I was ready to send the Matrox back but after I connected it to a 36″ Panasonic monitor and went thru the set up that matrox provides I was blown away, the picture was great. Its a little tricky to set up but well worth the effort, we also have a Mac with the Next size up Matrox and that did not have problems but we did need to call Matrox to get the install correct
    Tv One Productions
  • Adam Read
    August 24, 2011 at 9:45 am
    Thanks Philip
    and thanks for sharing your experiences. I still find it annoying that it’s so ‘fickle’. I’m of the belief that it should just work without any impact on the performance of CS5/5.5. Maybe I’m just an idealist 🙂
    Out of curiosity, what model Panasonic monitor do you have?
    ADAM
