Activity Forums Adobe After Effects Best hardware for the fastest final render time possible
  • Best hardware for the fastest final render time possible
    Posted by Sergio Cabrera on August 14, 2019 at 3:53 am
    I’m trying to find the best hardware to get the best final render times directly from AE.
    I’ve made a lot of research and tests, but still think it could improve.
    I’m right now using a 8700k with 48GB DDR4 2666mhz, with 4x SSD and a 1080ti (which is useless for the kind of projects I handle):
    SSD 1: OS
    SSD 2: AE
    SSD 3: Project and project files
    SSD 4: Cache
    Conditions:
    *Must use AE CC 2018
    *Must render from AE (not media encoder)
    *Must render in AfterCodecs (h.264 mp4)
    *Can’t use RenderGarden
    *Can’t use farm rendering since it’s only for image sequence, not final renders
    Do you think a 9900k would make a difference? More RAM?
    How can I improve final render times?
    Tero Ahlfors replied 7 years, 1 month ago 2 Members · 5 Replies
  • Tero Ahlfors
    August 14, 2019 at 5:31 am
    [Sergio Cabrera] “*Must render from AE (not media encoder)
    *Must render in AfterCodecs (h.264 mp4)”
    Why? You can get way better quality H264 outside AE.
    [Sergio Cabrera] “*Can’t use RenderGarden
    *Can’t use farm rendering since it’s only for image sequence, not final renders”
    Rendergarden etc. does have a feature that will automatically transcode the image sequence to a single file. Or you could set up a watch folder.
  • Sergio Cabrera
    August 14, 2019 at 6:03 am
    [Tero Ahlfors] “Rendergarden etc. does have a feature that will automatically transcode the image sequence to a single file. Or you could set up a watch folder.”
    I didn’t know that Rendergarden have such feature, do you know if I can get the final render in .mp4 automatically from rendergarden?
  • Sergio Cabrera
    August 14, 2019 at 6:21 am
    Ok, tried Rendergarden, it doesn’t work for me, I render from a script and there’s no way (at least that I know) to plant the seeds and avoid Rendergarden dialogs.
  • Sergio Cabrera
    August 14, 2019 at 6:22 am
    Plus, the original rendergarden scripts are encrypted so I can’t modify it to work.
  • Tero Ahlfors
    August 14, 2019 at 2:20 pm
    If you need the fastest final render time possible then you will need a server to make a render farm to and render to image sequences. That’s pretty much it.
