Activity Forums Apple Final Cut Pro Legacy Best Frame Offset for using Inbuilt Audio with FCP
  • Best Frame Offset for using Inbuilt Audio with FCP
    Posted by Ben Knight on December 12, 2012 at 8:11 pm
    Hi guys,
    I’m editing on FCP 7 using the inbuilt audio, and watching video on my computer… no external decks, monitoring, etc… just speakers plugged into my headphone port.
    What frame offset should I be using? I was on 0… and still felt that the video might be a bit behind the audio… but it won’t accept a negative value for Frame Offset.
    Any suggestions?
    Thank you!
    Ben
    Jaap Verdenius replied 13 years, 8 months ago 2 Members · 3 Replies
  • Jaap Verdenius
    December 18, 2012 at 4:18 pm
    I wonder if frame offset applies to this situation.
    Do you notice any difference when you set it to, say 30?
  • Ben Knight
    December 18, 2012 at 10:30 pm
    Oh, I haven’t tried that, but I certainly can. Working with 24 p pro res, would i still use 30, or 24? Can’t say I understand why your suggestion would help, but I thank you for it!
  • Jaap Verdenius
    December 18, 2012 at 10:48 pm
    It’s just to verify if the frame offset is influencing the latency at all in your setup.
    When you are using built-in outputs FCP should adjust this automatically.
    If you see no difference with the offset to 30 (which is max) compared to 0 then you know you have to look
    elsewhere for an explanation.
