Activity Forums Adobe Premiere Pro Best format to to use when transfering 16mm for import into premiere pro
  • Adrian Tecson
    August 5, 2005 at 7:51 am
    Look at the Decklink line of products, they’re you’re best bet I think at a great price point as well. From what I understand with their HD products, you get an SD signal simultaneously with your HD signal. My company uses the Decklink Extreme for our SD TV spot work. Theyre great and work quite well with PrePro 1.5. Check them out at http://www.decklink.com
