Activity › Forums › Maxon Cinema 4D › Best fluid simulator
  • Darby Edelen
    December 13, 2013 at 4:47 pm
    As far as I understand it, Realflow is pretty industry standard. However, Houdini has some pretty awesome fluid tools in it as well. The learning curve may be steeper with Houdini, but it can do much much more than just fluids. There’s also a learning edition available for free so you can test drive it.
    Darby Edelen
  • Victor Camacho guerrero
    December 13, 2013 at 5:22 pm
    I see. In all big house productions here in london, they were recommeding Houdini, but it could be great to know how much time I would need to spend in order to learn.
    would you recommend any of the plugin from C4D to learn?
  • Adam Trachtenberg
    December 13, 2013 at 7:21 pm
    If you already have DPIT Effex then I would start with that. It is the most complete liquid simulator for Cinema (not counting Realflow, which is more of an import plugin). The only other option is X-Particles which is easy to use but pretty basic.
    Another option would be to check out Blender, which is free. It has a liquid simulator but I’ve never tried it.
    December 16, 2013 at 10:46 am
    oh brilliant, i would give a go to DPIT then 🙂
    Many thanks
