Activity Forums Adobe Premiere Pro Best Flavor of Codec/file/wrapper
  • Best Flavor of Codec/file/wrapper
    Posted by Bill Olafsen on June 25, 2013 at 4:28 pm
    Anybody have a recommendation for a file type, codec/wrapper, to master to from Premiere on a PC? We are currently in the process of switching from FCP/MAC, which we were using ProRes, to Adobe/PC which we are currently mastering to Avid DNxHD. Not real happy with the results so we are looking for suggestions.
    BILL
    Gary Seabrook replied 13 years ago 6 Members · 11 Replies
  • 11 Replies
  • Shane Ross
    June 25, 2013 at 5:11 pm
    Well, what is the intended use of said mastering format? Delivery to a client? What do they want? Delivery to a post house for output to tape? What can they deal with? Or just plain archival?
    DNxHD is, IMHO, the best option for the PC. Open codec, readable by others, high quality. What do you find lacking about it?
    Shane
    Little Frog Post
  • Walter Soyka
    June 25, 2013 at 5:13 pm
    [Bill Olafsen] “We are currently in the process of switching from FCP/MAC, which we were using ProRes, to Adobe/PC which we are currently mastering to Avid DNxHD. Not real happy with the results so we are looking for suggestions.”
    This is a tough question. What do you mean by not happy with the results, and what do you expect to do with your masters?
    Premiere Pro CC supports DNxHD in MXF wrappers, so you don’t need to be reliant on QuickTime. Depending on what your problem with DNxHD is, this may help.
    AVC-Intra 100 (with CS6, AVC-Intra 200 with CC)/ MXF may be a good option. It’s documented and relatively open, but common desktop players like QuickTime or Windows Media Player don’t do MXF.
    I like and use CineForm from GoPro. It wraps in AVI or MOV and it’s available on both Macs and PCs. However, it is proprietary.
    For the long term, image sequences plus some kind of PCM audio (WAV/AIFF) are an interesting option, but can be harder to manage or play directly.
    Walter Soyka
  • Bill Olafsen
    June 25, 2013 at 6:38 pm
    The intent is to use the file as the “House Master” which all other files will be “Dubbed”(I’m an Old School Guy) from. Currently when using DNxHD with any encoder the resulting file has had its Gamma adjusted, we have tried every setting possible and cannot seem to get a clean file.
    BILL
  • Shane Ross
    June 25, 2013 at 6:49 pm
    Gamma adjusted compared to what? What is the codec of the current files? If you convert from some formats of camera master, there will be a gamma shift, as certain camera codecs don’t have the best compression to begin with (AVCHD for example) and converting to a more professional codec might shift things a little. I noticed this with AVCHD mainly…and in Avid. AMA linking to the camera masters, then the transcoded masters. Gamma shifted.
    With Premiere and it’s “lets work native with everything” mentality, I wonder how this will be dealt with? What are you rendering to? What codec? The default MPEG-2 one…or ProRes? There is a known gamma issue when converting ProRes to DNxHD too. One no one has solved yet.
    Shane
    Little Frog Post
  • Bill Olafsen
    June 25, 2013 at 6:55 pm
    Mastering to DNxHD from PP. Using DNxHD as source to encode to whatever, the gamma of the resulting encoded file is different than the original. The amount of Gamma adjustment is different based on what encoder might be used but it appears no matter what that the Gamma has been adjusted.
    BILL
  • Chris Tompkins
    June 25, 2013 at 8:04 pm
    Have you tried mastering to ” P2 ” format?
    Opens up on any NLE.
    Chris
  • Walter Soyka
    June 25, 2013 at 8:06 pm
    [Bill Olafsen] “The intent is to use the file as the “House Master” which all other files will be “Dubbed”(I’m an Old School Guy) from. Currently when using DNxHD with any encoder the resulting file has had its Gamma adjusted, we have tried every setting possible and cannot seem to get a clean file.”
    You are missing one of the big benefits of Premiere. You can bring your Premiere sequence into Adobe Media Encoder and output your multiple different “dubs” simultaneously (including both compressed deliverables and an in-house master for safe-keeping) without having to generate an intermediate first.
    In Premiere Pro CC, DNxHD support is native (it doesn’t have to rely on QuickTime) and is vastly improved.
    Walter Soyka
  • Shane Ross
    June 25, 2013 at 8:25 pm
    But what do you archive to with premiere? Surely you don’t keep the project and all the media. In Avid, you can consolidate only the clips used in the cut, with handles…but it’s media management is top notch, and Adobe’s is sub par. We also exported DNxHD Qts…or lately, Op1A MXF files.
    FCP…we exported ProRes QT files and archived those…and I still media managed the project.
    Can adobe CC media manage only footage used in the cut? I know it can’t with GOP formats like XDCAM or HDV (Avid and FCP can). And what about a DI (Digital Intermediate?) This is a standard thing to have…a DI master to make all your compressions from.
    Shane
    Little Frog Post
  • Steve Brame
    June 25, 2013 at 10:21 pm
    [Shane Ross] ” In Avid, you can consolidate only the clips used in the cut, with handles”
    The same can be done in Premiere’s Project Manager.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID5 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * CS6.x Creative Cloud
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Walter Soyka
    June 26, 2013 at 3:34 pm
    [Shane Ross] “But what do you archive to with premiere? Surely you don’t keep the project and all the media.”
    Actually, I do. Everything goes off to LTO-5 at the end of a job. But my work is very different than yours, and I doubt this would be practical for the kind of shows you cut.
    AFAIK, Premiere Pro CC still will not trim long GOP sources, but that’s not a part of my workflow and I haven’t actually tried it.
    It’s also worth mentioning that Premiere Pro’s Project Manager will not preserve things dynamically-linked AEPs and their dependencies, either. For me, archiving the whole lot is just simpler, and the amounts of footage I deal with allows it.
    Walter Soyka
