Activity › Forums › Adobe Premiere Pro › Best File Format for SD Commericials for Flip Factory
  • Best File Format for SD Commericials for Flip Factory
    Posted by Felix Underwood on November 20, 2009 at 2:44 pm
    I have a local media outlet that will now take tv commercials for broadcast in electronic file format. Any suggestions on the best file format and codec for standard def commercials that will be encoded through Flip Factory? I’m using PPro CS4 with a Matrox LE card.
    Jeff Brown replied 16 years, 10 months ago 2 Members · 3 Replies
  • Jeff Brown
    November 23, 2009 at 5:03 pm
    They should be telling you which formats are acceptable… otherwise you risk multiple (re)compression and serious loss of quality.
    -jeff
  • Felix Underwood
    November 24, 2009 at 1:48 pm
    Thanks for that, Jeff. Problem is, I’ve run into a lot of people using Flip Factory that aren’t very knowledgeable it its operation and thus are having me try different file types.
  • Jeff Brown
    November 28, 2009 at 2:19 pm
    I suppose I was not clear: Your “local media outlet” should be the ones providing the specs. They are the people who know what they use for playback.
    -jeff
