Activity › Forums › Adobe Premiere Pro › Best file format for decent image but fairly low file size.
  • Best file format for decent image but fairly low file size.
    Posted by Thomas Davies on December 10, 2009 at 10:59 pm
    I’ve tried 3 outputs so far, AVI gave me a 500mb file, WMV compressed was 4mb but looked terrible and uncompressed WMV was 3gb! Anybody know a format that’ll give me a file of around 60-100mb? Theres no audio and the file is like 700×550 or somwhere around that.
    Vincent Rosati replied 16 years, 9 months ago 2 Members · 1 Reply
  • Vincent Rosati
    December 11, 2009 at 12:53 am
    Doing compression tests can be time consuming.
    I recommend you create a new sequence that will be 1 minute long. Place your final sequence in it (nest it) and clip it down, selecting portions with high motion, transitions, cuts, titles, etc – stuff that doesn’t compress well.
    Now you can run a bunch of tests, and not have to wait 12 hours between attempts. Keep notes on all of the settings you are using, even for the failures. Include the compression settings, frame size, frame rate, etc.
    Enabling 2-Pass & VBR will give you the best result. However, note that using VBR will prevent you from being able to do exact calculations regarding program length and final file size.
    What compression to use depends on what you want to do with the video. Archive, web, kiosk, broadcast, etc.
    Just a few things to think about.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
