best fcp settings for 1080i footage to 720p output
Hi. A two part question about how I should be setting up my project in fcp:
1. My first question is related to resolution… my raw footage is 1080i, but my final product will either be viewed on vimeo hd (1280 x 720) or standard def dvd. So, should I just set up my sequences to be hdv 720, or is there a significant benefit of editing in 1080 and then converting to 720 with compressor?
2. My second question relates to frame rate and interlaced vs. progressive. As I mentioned, my raw footage is interlaced at 60 fps, but what would happen if I set up my edit to be 1080p24 or 720p24? Would changing my sequence setting to progressive 24fps negatively affect my image quality, or would my footage just look a bit more like it was shot on 24p?
Thanks for any advice you can offer.
Nathan
