Activity Forums Adobe After Effects best export settings for web (youtube, etc.)
  • best export settings for web (youtube, etc.)
    Posted by Aza Allen on March 9, 2010 at 6:42 am
    Well, I am an idiot. I knew I was making this project for the web upfront, but forgot to change my comp settings to square pixels, so instead it’s at NTSC widescreen (1.21), at 720×480 px, what do my export settings need to be to keep the aspect ratio the same and so it doesn’t get squeezed? I have way too much put into this comp to change the comp settings and adjust all my frames (unless there’s an easy way to do it with a plugin or script?)
    Thanks all,
    Aza
    Make sure to check out my Heroes Fan Film at https://ruesterprod.blip.tv
    Aza Allen replied 16 years, 2 months ago 60,207 Members · 1 Reply
  • Aza Allen
    March 11, 2010 at 2:21 am
    I had no idea it would be that simple…
    Thank you very much! For some reason I thought going from a 1.21 px aspect ratio to a sq px comp was going to involve a more complex solution.
    So, then, just to pick your brain, what if I wanted to do the reverse? Go from a square pixel comp to a 1.21, or even .91?
