Activity › Forums › Apple Final Cut Pro Legacy › Best Export Settings for HDV footage to DVD
Posted by David Mayer on December 17, 2012 at 8:58 pmI load my Sony HDV footage to FCP and let final cut choose the
Sequence Settings (HD 1440×1080 with Apple ProRes 422 Compressor).I export as Apple ProRes 422 NTSC 48kHz Anamorphic.
In Compressor I use standard DVD settings.
The DVD made in DVD Studio Pro looks pretty bad.
Are there better settings to use to export from
FCP?Thanks much,
DaveiMac 2.8 GHz Intel Core i7, 8 GB
OS 10.6.2
Final Cut Pro 7.0David Mayer replied 13 years, 9 months ago 3 Members · 13 Replies -
Stephen Smith
December 17, 2012 at 9:02 pmShould look good. How long is the video?
Stephen Smith
Utah Video ProductionsCheck out my Motion Training DVD
Check out my Vimeo page
David Mayer
December 17, 2012 at 9:05 pmVideo is 30 minutes.
Forgot to mention: I capture using Capture Preset:
HDV-Apple ProRes 422iMac 2.8 GHz Intel Core i7, 8 GB
OS 10.6.2
Final Cut Pro 7.0 -
Stephen Smith
December 17, 2012 at 9:08 pmAre you using the “DVD: Best Quality 90 minutes” setting in compressor? I recommend just going with the setting and not changing it. It should look great.
Stephen Smith
David Mayer
December 17, 2012 at 9:37 pm1. When they move, their image follows
them – kind of blurs behind them as
they move.
2. Image is just not crisp.Looks Much better in FCP.
Dancers are fairly well lit with LED light.
Camera is 20 feet away.
Dave
OS 10.6.8
Final Cut Pro 7.0 -
David Mayer
December 17, 2012 at 11:24 pmgood question
looks equally bad on computer and TV
has a little bit of fuzzy VHS quality to it, too
OS 10.6.8
Final Cut Pro 7.0 -
Stephen Smith
December 17, 2012 at 11:27 pmAre you using the setting I mentioned in compressor un altered?
Stephen Smith
David Mayer
December 18, 2012 at 11:51 amIn Compressor, I start with 90 minutes Best Quality.
This is the best I could customize:
MPEG-2
Mode: 2-pass VBR Best
Average Bit Rate: 7.7 – I bumped this up but it seems to not be able to go higher.
Maximum Bit Rate: 9.0
Motion Estimation: Best
Allows up to 67 minutesCan I customize even better for a short movie?
OS 10.6.8
Final Cut Pro 7.0 -
David Mayer
December 18, 2012 at 11:52 amCan’t find any mismatch.
OS 10.6.8
Final Cut Pro 7.0 -
Richard Van harderwijk
December 18, 2012 at 1:07 pmHi
“…I export as Apple ProRes 422 NTSC 48kHz Anamorphic…”
Try export with sequence settings and let compressor do all conversion.
It looks as if you do two conversions, one -only?- scaling in FCP, from HDV->NTSC and then in compressor conversion to MPEG2. And the standard setting 90 mins should work fine.
Stephen Smith
December 18, 2012 at 4:25 pmThis is how I like to make DVDs and they always look great.
I go to File, Export, QuickTime movie. This will export your video into the codec that the sequence settings are set to. Make sure Setting is set to Current Settings. Make sure Make Movie Self-containde is checked.
Then import the movie into compressor. Drag on the Best 90min DVD setting and don’t change anything. Export it out and then bring it into DVD studio pro. It works like a champ every-time.
Stephen Smith
